Toyota Yaris 2008 Hatchback Problem (Help)
Ralph saad
Hello everybody,
i have a problem in my toyota yaris 2008 hatchback.
the steering wheel axe is releasing heat on my feet.
Does anyone know what would be the solution?
Thank you
Hello everybody,
Thank you
Please clarify, do you mean steering wheel shaft at floor level or heat appears to be coming from that area?
yes Bos, the steering wheel shaft at floor level is getting hot which make all the shaft hot.
Is it normal that the steering wheel shaft to be warm?
When i put my hand on the nearest point to the steering wheel it is hot.
