Bulb Change In Headlights
pasherp
having problems getting access to rear of main lights to change bulbs.Am I correct in saying the front bumper has to be removed in order to gain access to remove the headlight units.
please advise,cheers
if it's a T25 it doesn't have to be but some find it easier.
its a 54 plate 2.0 litre vvti tspirit auto t4 top spec with all the toys
I managed by 2004 Avensis .... the near-side was ok, but the off-side was a PITA .....tried all sorts, but in the end, just constant trying different ways, , leaning the water bottle spout out of the way is as extreme as I had to go,.... but lost a fair bit of skin of my knuckles (and the neighbours kids learnt some new words).....
Once it is off, you can file back a couple of the tags .... just enough to make it easier next time
