Toyota Hi Ace Diagnostics Program
kellyman
I have a Toyota Hi Ace 2002 D4D engine (2KDFTV) with an engine fault. The engine dies occasionally and it is using a lot of fuel. I’m looking for a computer diagnostics program that works with a laptop. Can anyone recommend a good one
Toyota Hi Ace Computer Diagnostics Program
This may be similar to what you are after
Diagnostic Tester-2 for TOYOTA and SUZUKI
Toyota Intelligent Tester2 IT2 with Suzuki only with test card diagnostic for Toyota and Suzuki.
There is no memory card in this device. When using IT2,pls dont insert the two card at the same time and also dont insert memory card. Because the memory car will slow down the running speed of the device.
1.Touchscreen & back lighting control
2.oscillograph function
3.Easy & quick
4.Usefully
Check it out on this link
autodiagshop.de/wholesale/toyota-intelligent-tester2-it2-with-suzuki.html
I am posting to assist but have no experience with the product!
