My 1999 Rav4 Problems.......
David William
my 1999 RAV4 is having some strange electrical issue.The gauge cluster has stopped working along with the turn singles i also can't use power locks or power windows and i am unable to shift my automatic transmission into drive.. but the head light still works.. can anybody help me reagarding this mater??????
Hi David and welcome to the club.
Have you checked the fuses that are under a pull-off cover down by the steering column in the facia as there are fuses there that are in the supply to these operations.
Del
yep - I'd check the fuses near the footwells to make sure theres no water = corrosion going on and that any earth connections are ok.
