Is There Anyone Using Iphone 5 With Toyota Inbuilt Satnav System
atul
I have avensis 2010 model which has tns510 satnav system. Paired my iPhone 5 with the system but unable to receive calls but can make calls efficiently. Any one with similar experience and any tips to resolve the issue.
Hi
I have the same problem, seems to be common to the iphone5, not only with the Avensis.
My iphone4 worked fine, but the 5 works some times or I have to go to audio source on the phone when a call comes in and select iPhone and then Toyota before it will come through on the car.
Apple forums are full of complaints over this matter.
Hi Again
Further to my last post, I have been in touch with both Apple and Toyota.
The problem, according to Toyotas bluetooth specialist, is that the TNS 510 touchscreen system has a software problem that is being looked in to.
At present the iPhone 5 is not fully compatible with this touchscreen.
He could not say when a fix would be available, but changing the audio source on the phone when a call is answered and then back to Toyota will work.
