30Amp Fuse In Engine Fuse Box Blows
Hi there! I'm a new user here. I have '94 model of Carina E. When I swith on with the key, the 30AMP (F32) fuse in engine fusebox blows. It is sayd to supply F6 and F7. I have already removed F6 and F7 and it still blows. Have anybody an idea of what the problem can be?
hi,
Whats happening is simple ,you have a short circuit ,ie a power wire is touching the car earth[body] whats not so simple is the cure, it depends how good you are with car electrics, at min you could do with a wiring diagram and then carry out a process of elimination. if you are not competent you are going to need the services of a dealer or a auto electriction.
This is AM2 fuse in the main box. Any idea of what it feeds?
