Fuel Temp Sensor Location D4D 08 Plate
andersonk
Can anyone confirm where the Fuel Temperature Sensor for an Avensis D4D 2008 is located.
check with area close to fuel filter of even on it
Thanks Igorus, I notice that there appears to be two sensors on the side of the fuel pump one which looks like your standard water sensor and is jus below the pump and the other that looks a bit more chunky and is more on the body of the pump, the only thing on the fuel filter is the water in filter sensor which the previous owner cut off!
