Avensis
smokinmyman
I believe that you can obtain engine fault codes from the 7a-Fe engine by shorting two wires in a connector block somewhere and reading the number of flashes of the engine error light on dashboard.
Can anyone tell me where this block is and where can i find a list of the fault code definitions and any other info that will help to use this diagnosis system. I read somwhere that the Toyota onboard diagnostic system is one of the most user friendly out there . I hope they are right!!
