Best Fuel Additive/cleaner For 1.4D Yaris On 2007 Reg?
apples69
My 2007 reg yaris 1.4d has 76k on the clock and i want to try using a
fuel additive/cleaner to impeove mpf, i am currently getting 485 on a full tank, which costs £55 to fill up, anyone recommend a good cleaner which will clean the full system and improve mpg?
BG 244 as an initial clean up then either Archoil 6200 or Millers Ecomax at every fill of Shell V-Power diesel
You will achieve better long term results by reading and following what Prius owners do:
pulse and glide
anticipate so less braking
don't accelerate hard when engine is cold or up hills.
A competent driver can reduce fuel consumption by 10% ...
apples69, are your tyre pressures ok? These can also have an effect on fuel economy.
Italian tuneups are best.
Edit
and free.
and fun.
All of the above but I like Forte diesel additive, normally only available to the trade but it can be bought on the Bay.
Pete.
