Noise From Air Filter Housing
markkea
Has anyone else experienced a sort of rattling noise from the air filter at low revvs.? I have changed the air filter and pollen filter, but it is still doing it.
Any ideas gratefully received!
Mark
I have just swapped the filters like for like and everything seems OK - 4 clips on the lid fastening it down are all in place. I cannot see anything else loose.
'Noise When Rev Needle Is Between 1500Rpm And 2000Rpm '
Type this into the search box and have a read mate, not sure if it is same as your problem but could be worth a look,
Regards phil
Thanks for that Phil. I have taken the box off and there is no old foam underneath so I have padded it out with some pipe lagging I have cut up and fingers crossed this seems to have got rid of the noise.
Thanks very much!
Mark
No worries mate, glad to help
Regards phil
I used silicon sealant to resolve the same problem a few years ago. Still going strong.
