Several Problems Happedn At Once
maverick11
Hello,
I would like some advice, I drove my car last saturday, and noticed 4 things. My indicators are not working(but hazards do), my speedo is not working, and on my dash i have the ABS and handbrake light on. I was wondering if this could be a fuse, or is it something more drastic. Any help or advice would be appreciated.
Regards
Patrick
Hi Patrick,
You may have a blown fuse - ECU-IG 5A fuse under dash, by drivers right knee, could be the culprit. I checked my Haynes manual and some of those circuits use that fuse.
Check all the fuses and if you replace lets hope there is no short circuit going on, or the fuse will blow again.
If none of the fuses have blown, I would see an auto-electrician.
Konrad
