2000 Gstd Problems
davidh
Hi Guys.
I have had a Avensis GSTD for three years now, and there are a couple of problems I would like advice with.
The bulbs behind the central fascia which should light up the vent. controls are tempermental, only lighting up after I thump the side of the central console. How can I get at them to check if they are loose or need replaced?
Secondly, when I start the car on a damp or cold morning there is a squeal from the power steering fanbelt. This usually lasts for about ten minutes, presumably until the bely has heated / softened up. Any suggestions?
Tanks, Davidh.
