Abs Light Turns On & Windscreen Wipers Stop
dnivdniv
Have a V reg 1.8 avensis & very reliable however have this problem that seems to be getting worse.
Started off when starting the car the ABS light stayed on & windscreen wipers / and or indicators would not work. The speedo also occasionally did not work. Restarting always sorted out the problem
Now I have had two occasions when the ABS light kicks in when going along & the windscreen wipers stop working :-< . After around 3 secs the light went off & the windscreen wipers restarted.
Anyone out there have any ideas ???
