2003 Rav4 Petrol (1998Cc) Obd P0300 &p0301
rumtop
Hi
I have been investigating a Cylinder No 1 misfire.
Yellow engine warning light constant or flashing
Engine starts no problem but idles a little lumpy
When driving there seems no loss of power
So far I have replaced air filter and all spark plugs.
I have also swapped cylinder No 1 with cylinder No 2 fuel injector.
I have also swapped cylinder No 1 with cylinder No 2 ignition / coil module.
I have cleared all codes but still get obd P0300 &P0301.
I want to try replacing ignition lead to No 1 spark plug but i have been unable to source a replacement, anyone know where I can get one from??
Any other ideas regarding this fault would be a great help.
Many thanks
Phil
Hi Igormas
Thanks for reply
And yes I have cleared all codes (I have cleared all codes but still get obd P0300 &P0301.)
NB
The ignition lead to Spark plug one is the wireing harness to the ignition /coil module
OK Phil - 'give up, what model is it?
I'll guess at 2003 Rav4 Petrol 1998Cc
Might be just with a 4 number code........
I was going by the thread title..................................
Hi
Yes a 2003 Rav4 Petrol 1998Cc
Not sure where to go now, checked harniss as much as possible today.
Reset /cleared all the codes again just to make sure
P0301 code returned after a few mins of engine running ,
missfire cylinder No 1 and engine still lumply on idle as you would expect .
Must read slower!
If you've swapped all the components and the mis has stayed with No1, you need to do a compression test. Just make sure there are no leaks around the inlet manifold. Spray some WD40 around it and see if it revs up/smooths the idle out.
http://www.ebay.co.uk/itm/PETROL-ENGINE-AUTOMOTIVE-COMPRESSION-TESTER-KIT-DUAL-SCALE-GUAGE-TWO-ADAPTORS-/150763546549?pt=LH_DefaultDomain_3&hash=item231a3527b5
