2008 Avensis Bonnet Stay Clip
ruggz
I am hoping someone can point in the direction of a diagram or some photos.
I have a 2008 avensis estate and when I bought it there was no clip for the bonnet stay arm, I have just purchased the clip, but I am still missing a part as there is nothing under the rectangle hole in the engine cover for it to fix to.
Should there be a bracket that fixes to the chassis or is there a bracket that fixes to the two holes near where the clip should be.
Any advice and info would be appreciated.
Hello mate I think you will need to remove the plastic covers above the radiator to fit the plastic clip, here are a couple of diagrams just click on them to enlarge.
Pete.
post-74463-0-84583100-1352994527_thumb.g
post-74463-0-83357100-1352994546_thumb.g
Thanks for the diagram, managed to get the new clip on even if it was a bit tight
