Interior Lights
valentino 46
Hi everyone, just picked up new avensis , and wondered if anyone can tell me if there is a switch to turn on any interior lights When opening any door , no lights are operating. . Thanks.
if it's like most other cars you will have a 3-position switch that allows for light on when door open, light on with door closed & light off (even with door open).
as above it should be in the manual ;)
It may be just the 7.5 amp dome fuse blown,this is in the fuse box near your right knee below the dash when sat in the drivers seat.
Pete.
I have the problem as OP light works if i switch on manual but will not light up with the door open
