Dash Clock Blub Replace Mk1 2002
Dermot
I have a blown bulb in my dash clock. Right in the middle where the speedo ends and the rev counter starts.
It's a 2002 Mark 1. Been told it's 2 screw to take out the surround and 4 screws inside to get the clock itself out.
Can someone please tell me what type of bulbs I need? and if i unplug the clock will the mileage reset or anything bad ecu wise happen?
Thanks.
I have just replaced all my bulbs 2 screws to remove the surround then its 3 screws to take out the instrument panel you will find 2 harness connectors behind the instrument panel pull them out and remove the instrument panel it will not reset your mileage just your trip and clock will be reset
The bulbs for the center console are wedge 286 type 1.2w. They pull out of the holder.
for the dash eBay item no 330815848838
