Locking Wheel Nuts
andyroot
holyy mack your in trouble..the only way i can think of is to hack them off although u might have to get studs on ur axle thats what I think anyway better to ask a good mechanic
try manufacturer in case you can get a replacement
otherwise get a big drill and Ti Nitride bit!
I'm sure your friendly Toyota dealer would be able to help you out.
They'll have some "universal" key.
Our branch of kwik fit says it happens all the time and they have a speial tool that will fit most of them. Fit it to a an air gun and it will rip it out! It will ruin the locker though so a new set will have to be purchased!
I was suprised how easy mine come off to be honest! hardly secure to say the least!
Yes, if a thief comes round towing a kwik fit garage :P
Piece of cake if you have the right tools. done it twice on my surpa.
heat up the nut with a blow torch, quickly smack on a bolt one size too small for the nut, then get a !Removed! big torc wrench and bobs your uncle.
thats how kwik fit removed mine twice, but you may have to take your ownership papers with you before they will do it.
just to prove the motor is yours
then buy a new set of nuts and have a spare key cut.
then ask somed=body you trust to look after the spare key.
:hokus-pokus:
