I recently changed the timing belt on my 93 corolla 20v silvertop engine. the trouble began when i started the car. it started fine and the revs went up to 2000 rpm, then dropped to normal idle [ around 800 rpm ] but then dropped the revs fell even further and sounded rough so i turned the engine off. any ideas wot is wrong ? im currently not driving the car but will be insuring it next month so i need it running sweet. i was careful not to move anythin to adjust the timing when changing the belt. please help. :help:
