Antifreeze
andrewm1
Hi after i replaced my thermostat i lost bit of water i need to top it up but where can i get green antifreeze or does it not matter what antifreeze i put in to top up
Put the details of your car into eurocarparts.com or Opie Oils.com and it should tell you the type
Regards Phil
I think you can get it ready mixed at you local Mr Ts. So why bother mixing different makes.
Ask your local Toyota dealer which BS standard does the toyota anti-sneeze complies with - then go buy a comparable type.
