Pwr Mode Button Not Working
PatW
Hi all - I just noticed today that the PWR mode button on my Prius no longer works. When I press it nothing happens at all - no PWR light on dash and no change in throttle response. Eco and EVO buttons still work fine.
I don't use it very often but it was working last time I tried a few months back.
Is there anything obvious I have missed before I take it to Toyota for them to take a look?
cheers
Patrick.
Can't think of any situation that would prevent PWR mode operating, it must be faulty, could be the switch.
  • 4 weeks later...
Had the same problem on my Auris, connector failed, they sorted it in about 25mins and got me on my way full of caffeine :-) must say always been very lucky with my local dealer.
Never pressed mine and not likely to either, it’s a stupid addition on a car built for economy.
I drive 90% of the time in eco mode and when I do venture out onto the motorways I just switch it off and let the car run in normal mode.
I have heard of someone else with same issue and turned out to be the PWR switch issue
Go on, press the PWR. You don't know what you're missing.
I normally drive in ECO but do use PWR from time to time when more power is needed. The honourable example is when I'm joining fast-moving traffic and don't want to hold people up while i accelerate. The less honourable example is when I have chosen the wrong lane at lights and use PWR to beat the other traffic.
ECO does work well on motorways provided you are travelling at a steady speed.
I only use it to pull away a little quicker from a standing start. Normal mode I find is as quick and less noisy when i'm already moving.
