Sr180 Major Performance Dip
badaz52
Hi there,
I have a 2008 plate Auris SR180, absolutely love the car, performance is fantastic. Over the last few weeks though as with most people the car has taken a massive dip in performance. The turbo is incredibly flat and at times my foot is completely to the floor for 30 seconds or more before the turbo kicks in and I am flying home. I am assuming that the turbo is operating as it should but it just doesn't seem to have that explosive raw power anymore that it had a few weeks ago.
The car is still under warranty with Toyota until next April and although I should really book it in asap I wondered if anyone else has had the same problems and it hasn't been linked to the EGR valve?
My average MPG has also dropped from 42 to 38 in a matter of days and keeps falling gradually.
Any advice would be greatly appreciated.
Thanks!
Adam.
Hi Adam - I have exactly the same car. If it's not an EGR issue then I'd be looking at a very blocked DPF. These engines need to be warmed up & used regularly, short runs from cold never get enough heat into the motor to keep it clean & regenerate when necessary. As it's still under warranty, take it to your nearest Toyota dealer as soon as possible. It's up to them to find the problem & offer a solution then.
I'd also consider the fuel you use.
If its supermarket fuel then give Vpower diesel a try. You will probably notice a difference with 5-10 miles if you fill from empty.
The EGR is also worth a check if you have the tools and the know how.
Try changing the fuel filter and running some Shell V-Power derv through it like Davey said. Also a tin of BG244 or some Archoil 6200. I'd plump for Bg244 love juice...
