Starlet Sr Engine Swap
ciaranjdm
Hey I own an ep91 starlet sr I'm looking to do an engine swap to get some real power, although the obvious choice would be a glanza lump I wanna keep it n/a I was thinking could I get a 4age either a 20v or 16v any suggestions thank you ..
I wanna keep the swap as straight forward as possible would the levin engine go in with standard mounts ..?
There are a few Starlets with 20v's in so it is possible, as for straight fit? - should be, working on the 4EFE was fitted to the E10 Corolla as was the Silvertop 20v. You will need the 20v mounts. The tricky part will be the wiring.
