Removal Speedo
mohin
hi everyone i was wondering if you could help me remove the speedo on a toyota avensis 1998 the reason i have to remove it is because some of the lights have stoped working thanks for all the advice
there's 2 screws pointing upwards on the plastic surround of the clocks,
remove them and carefully remove the surround,
there's a further 3 or 4 screws holding in the instrument cluster itself and either 1 or 2 electrical connector blocks at the back remove those and hey presto !!
the bulbs themselves are in these little plastic holders that twist and pull out of the back of the clocks, all very easy to do !!!
