2001 Yaris Ignition Problems
Richard Davies
Recently the ignition on my 2001 Yaris has become hard to turn leading to me cracking the plasic on one key.
It still works, but I need to jiggle the key a bit to get it to turn, rather than use much force.
I've tried with a spare key, & has similar problems, which suggests the problem is in the ignition slot rather then the main key getting worn.
I'm wondering if I need to go to a Toyota dealer to sort things, or will an indepentant workshop be able to fix it.
