Electric Window Not Working
allotment man
I have a 2007 deisel Yaris. The front passengers electric window is in the closed position and will not open or even move.
There is not any noise coming from it. I have tried operating the switch on the drivers and passenger doors, but nothing happens.
Outside temperature is above freezing, so that is not a problem. Any ideas ?
Broken wire in the run to the door or loose connection or electric motor seized.
(IIRC the same fuse covers both windows so unlikely to be a fuse).
Have you by any chance pressed the button on the drivers side next to the 'windows' buttons.
This button disables the passengers window!!
^^^ This!
Thanks for the reply. Yes the window disabling button had been moved.
Not something I have ever touched, but it seems the dog has !
Many thanks.
This problem has turned up on here at least once before.
I managed to do knock the switch a while back & wondered why the passenger window wouldn't go down.
