Alarm Set Unset Buttons Not Working On Ignition Key
Avensisitis33
Alarm set unset buttons not working on ignition key .
Changed Battery after I found it wouldn't set or unset alarm . Strangely it will unlock the doors ( sometimes ) if I walk round to the passenger door and pink it right beside the door but nowhere else so I'm supposing that the key transponder / signal sender is not working and the key is faulty . Anyone any advice . Only happened today . Will not lock the car by remote now only by manually key locking drivers door .
Hi mate what do you mean wont set the alarm?? is your alarm not built into the central locking system by remote on key??
and have you another key to try and see if your key that you are currently using is failing??? where are you from??
Living in Dublin . Only have the car two weeks . Only got one key . The key will not central lock / set alarm after journey when I arrive home . This is an intermittent fault . Sometimes it locks / unlocks as it should . But now its happening every day . Oddly enough the steering wheel lock unly locks sometimes so I assume someone forced it or broke it in the past . Perhaps it was stolen in the past . Another odd thing is that when the key stops operating it WILL lock the car but ONLY standing beside the passenger side door and even then you have to be standing directly beside the door . Really puzzled :(. Any advice would be appreciated .
hi colin did you buy the car private or dealer?? i would ask the last owner to look for the spare key...and find out if it was a stolen recovered car...im in tyrone if you had of been closer i could of run a diagnostic test on it....i'll ask around about your key problem to see if anyone can come up with something?? im not sure what to think of it??
Ha ha , last owner polish guy who spouted it had timing chain done , new discs , full service , new tyres ( ha ha ha :) , NONE of which was done :) and asked about keys but told it was the only one .
Regarding key not communicating with central locking / alarm .
I have noticed that the times alarm setting won't work are the times when I return to the house and don't set alarm / central locking IMMEDIATELY . If I stop car , get out and press lock immediately it WILL set . IF I spend 5 minutes taking out messages , or working on car , or cleaning it , it will not set , so perhaps it's a time thing . Very confusing .
god i'd keep and eye out incase he steals it back sorry if that sounds bad but it has happened!!! have you tried to resync the keys to the car and see if that helps?? get yourself a chain and padlock and lock the chain on the steering..have you asked for advice in your toyota dealer to see if they have a heart and help you in some way without digging deep into your pocket??
yep, that thought occured to me the moment i bought it :) will almost definitely have to hand her in to a car electrics specialist as i dont think its solveable , the other strange thing is that it seems to set and reset no problem AWAYfrom the house , its as if someone or something has something jamming the signal ,really strange, little paranoid regarding security on the car and house but thats normal living in dublin around christmas, gotta be careful.
yeah its a strange one...has no one one here from dublin or closer to you not got toyota techstream diag???
have you tried a new good branded Battery in your key? and is all your door locks opening and closing when you put key into door lock?
just verified one thing and that is that the problem ONLY occurs outside my house. so the signal is being jammed by some signal closeby. strange, very strange. i did buy a brand new Battery from an automobile key company and tested it and away from the house the signal will work some distance from the car.as upposed to outside the house where being right beside the car i cant set the central locking. never heard of this happening to ANYONE.:(
TIS A PUZZLEMENT.
what is toyota tech stream diagnostics????
i did purchase the dash command bluetooth app for the car and it does work with the car streaming data but it only shows problem with egr faults coming up but within threads others have said that the 2 litre petrol does not have egr. agin puzzled. it doesnt show things like electrical faults.
hi colin techstream is toyota's diagnostic tool..i think you can get 1 of those keys deleted from the ecu/immob memory just hope your's is the master key...and have you any thing there at home that will jamm or break signal from your key??
Thought long and hard re what could be jamming the signal so turned off wifi in house , also bluetooth and GPRS and wifi on phone , tried everything , aaaaaaaaaaah , will be getting Toyota to have a look in the new year :( will have a thrifty christmas saving up for it :) ha ha , thanks anyway .
