Problems After Engine Replacement On Toyota T180?
gilia
Yer! I did... Had to have another one within 10k!!!... My mate CharlieFarlie has had a couple of engines an all!
was that when dealers were rebuilding rather than using Toyota supplied replacements though?
As far as I know all recon engines should come with some kind of warranty.
I wonder if anyone had problems, after engine replacement, on toyota T180!
Have you? Would like to know what your problem is.
meant to add, mines been running ok after 7000 miles
What issues are you having?
We have done over 25k on our new engine (fitted in November 2011) with no issues what so ever
I do not have any problems. Everything is ok after 10000 miles. My average fuel consumption is 7.8 l/100km (≈ 36 mpg) and is because the most time I drive in the city. I made this post because I heard a lot about TOYOTA ΄s reliability. Since yesterday no one mentioned any problems with their T180 which shows that the problem in solved.
  • 4 months later...
Hi
We had our engine replaced in Oct 2011 (but only done 6k) and still have problems, in fact we now have more problems! It seems it is mostly to do with the EGR valve which we replaced in March but after 300 miles our management light has come on again. I want to get rid of the car as I have lost all faith in it and Toyota :-(
I understand how you feel but if somebody charged you for the EGR valve they should be explaining why it didn't work.
Warranty on the replacement engine is for one year.. You still have the balance of the 7 year extended warranty if applicable..
Take it back plain and simple.. If no joy at the dealer contact Toyota GB without delay !!!
