Yaris Radio Fault
womble171
Hi all, I am new to forums and interweb so please be gentle!!
A few days ago the radio in my yaris started to make a crackle noise from one of the Speakers, about half an hour later the sound packed in totally.
I have a little knowledge around cars so I took the radio and cd out to see if there was a loose wire as we have only had the car a couple of weeks....everything was good.
The radio and cd still seem to work, i.e, you can play a cd and change stations but no sound whatsoever??
Is there a fuse that could have blown or does the display/trip computer act as an amp and that has blown?? If so, would I have the same problem if I installed a bog standard radio/cd player from Halfords or somewhere?
Any help appreciated as the wife is a terrible singer!!!
Forgot to mention.....it's a 51 plate yaris GLS 1.0 if that makes a difference?
Thanks,
Neil...
Hi Neil
I suggest first off removing the stereo and check the connections on the back and check the harness.
Hopefully its just a loose connection
