T180/sr180 Bhp
forevered
I wouldn't like to argue who has, but I can tell you this. Most owners who have fitted them could go to a higher setting & achieve over 220 bhp & 350 lb/ft of torque easily - but it's only a matter of time before the limp home mode comes on. Why ? Because the extra fuelling & turbo pressure takes the sensors way outside their normal working parameters and they call time. In addition to that, it also puts a huge amount of pressure on the particulate filter & the clutch. Either one will fail before long if you run around on max power settings permanently. It could be a very expensive route to go, but your choice ..........
