Avensis 2006 Upper Dash Pannel Remove
JAPCAR
Do somebody can advice me how to remove panel around two center vents and lid above the stereo?
I don't know how to remove the panel but the long narrow panel which has the cup holder and the rear screen demister pulls off easily. Start from the passenger end and pull forward to uclip it. Perhaps there will be screws behind there?
hi!
it is very easy, remove the grey stripe with the cup holder and passenger seatbelt warning by pulling put gently from one side to another.
then remove the connector from the seatbelt.
under the 2 vents you can find 2 screws that holds the dash panel. then pull it out gently.
(i have the 2006 with computer instead of glovebox and i have some wires connected also, but i don't think is your case)
cheers,
