Battery Changing
kegster
Hi all, im new to the forum so apologies if this has already been asked. Changed the Battery on my 2006 2.2d Avensis, i have lost the volume on my radio, everything appears ok just no sound. Any advice please.
Regards Kev
Hello and welcome kev,
I have had the Battery off many times on my 2.2 avensis without any problems. I would check the fuses but if the radio cd is lit up then it shouldn't be that unless the radio has an onboard fuse for its power amp ... very strange as the radio is not coded either.
regards .... Pete.
Many thanks Pete, whilst changing Battery i connected another power supply (i didn't know it wasn't coded}, i shall try again. One thing that was strange the one touch operation on the windows stopped working, but started again shortly after. I shall post up if i can cure it.
Regards Kev
