Rav4 D4D 2002 Rpm Jumping While Cold, Stalling.
ginnnts
So it became colder in my country (-15C) and one morning my Rav just didn't start up! I still had half a tank summer diesel left (high mpg, you know :D ) and i added like quarter of tank of winter diesel, it was fine for a few days, but than a colder weather came an car just died!
My first thought was to replace fuel filter, so I did an I emptied my diesel tank and fillet it with winter fuel and after long starting, engine came back to life, but rpm was jumping a lot (1100-2500rpm) while engine was cold. When it heated a bit, rpm came to normal ~1200 on Idle Up.
Than I took it for a ride. At first I thought it was ok, but than I switched in fourth and pressed on gas pedal harder and it didn't accelerate past 2500rpm, stalled for a bit and then engine like cut off for a moment and then it started to accelerate, it repeated many times till car just stopped.
After long starting engine started again and i drove to my garage as if nothing happened (no stalling, no engine stopping).
The next day everything repeated but this time problem didn't just disappear. I barely got home, engine just kept cutting out till car fully stopped.
Does anyone had similar problem?
it looks like you do still have a n air in the fuel system with an impu;se filtration
try to bleed the system
hmmm I don't seem to be able to find bleeding screw! Is it on filter head or pump? I thought system was self-bleeding...
