5Th Gear
samosa
hi,
I got an Auris and it has an indicator which tells you when to shift gears, it tells me to shift to 5th when doing a touch over 30mph. I've applied this to my t-sport but am not quiet sure if this is correct
when do you guys shift up to fifth gear?
I doubt it would apply to your Celica unless it has the same gearbox and engine.
I personally go into 5th between 35 and 40mph depending on traffic flow. I've had my car in 5th down to 30-32ish but it doesn't sound happy at such low revs!
