Check Vsc System?
gavin77
Hi my fathers avensis as started displaying this fault. On start up it says check vsc system the traction control sign stays on as does the abs sign. Any ideas would be a great help. It's a 2010 d4d 2.0. If u turn it off and re start it up it gis off?
On my T25 Avensis 2L D4D T Spirit Manual 2005 it turned out to be the Yaw rate sensor under the passenger seat. You need a ODB2 scanner that can communicate with the ABS computer to get the fault code. Many scanners can ONLY read ECU codes
