Retrofiting Front Fogs ?
flozse
Im wondering do i need to buy full collum with fog lamp switch to wire front fogs onto original loom ?? any advice or tips are very wecome thanks :)
Has your car got the inner ring fog light switch on the main light switch stalk?
I'm not sure what exactly is or isn't fitted but you'll certainly need a stalk with the switch, you'll need to pick up the wiring somewhere as it's not fitted to the blanking holes where the fogs go, you'll probably need a relay and a fuse, and perhaps need to fit a bulb in the dash for the warning light. Obviously you'll need the fogs complete with their fittings and bulb holders etc.
