How To Replace Avensis 2004 Hatchback Window Switch?
ak_wf1
Hi
My avensis 2004 hatch had a problem with the driver side 4 way window switch in that it would not work. It would only work to wind down easily but then i had to fight with it to wind the window back up. It would not work to lower/windup the other 3 windows. So i got a replacement but cand figure out how to replce the new for the old one. Do i need to take out the door panel or just prop the old switch out?
yes you need to pup the door panel of and unclip the switch from the back
No need to take door panel off , use a flat screwdriver or butter knife and lever out the switchbase and then disconnect the connector.It is only held in place by a spring clip.
