Where And How To Change 2002 Petrol Fuel Filter Please
jako999
Hi all and as its New year eve Happy New Year.
I am going to sort out the injectors soon but I may as well change the fuel filter as well so where is it on a UK 2002 petrol 2.0 engine code 1AZ-FE there is a long tank by the back wheel is that it? Is there a how to video any where and correct part number?
Thanks in advance
Trawling through my Haynes manual (don't tell Anchs ) as I have a 2002 model it says "Note: The fuel filter on 2001 and later models is integral with the fuel pump module in the fuel tank; there is no routine maintenance interval for fuel filter renewal on these models."
Well if thats what it says then great but it does seam a bit strange you would think it would get blocked up at some point.
It does seem odd but even the Beano (Haynes Manual) is correct, there is only a strainer in the tank.
