Scv Valve Service Bulletin?
Auristi
Hi
Is there TSB for SCV valve? I have some starting problems with my Auris 2.0 D4D.
I have found post in this forum, witch deal with modified SCV valves and reflash...
My starting problem:
Engine almous starts but then stall and continue to crank. After 2-3 second, it starts. It does not do it every cold start.
Could the clogged DPF cause it? I have been some problems with DPF also..
Thank you in advance..
