Recent Rav Temperature Question
In my previous 09 Rav if I set the temperature to 22 degrees I would be hot after the Rav had thoroughly warmed up and would drop the temp slightly, in my current Rav I find that I find 22 degrees isn't warm enough even after a thorough warm up (30 miles).
Anyone else noticed this in the current Rav or is it me....?
Gus
Yes. They changed the mapping of the heater computer and gave you coloured dots on the buttons! It is definitely cooler than the old system but it gives you chance to play with higher numbers!!! I'm nesh too and find about 23.5 is comfy. It also takes longer for the face level vents to automatically revert to fresh air.
