Abs In The Snow
KingToy
In the current snow conditions I got stuck and was having difficulty getting out. Fortunately, I eventually remembered that the handbook states you should turn off ABS to enable you to rock the vehicle in order to free it. It worked for me thank goodness!
"handbook states you should turn off ABS to enable you to rock the vehicle in order to free it."
​ABS Anti-lock Braking System are you sure?, TRC possibly.
Hmm, message board it putting thing at the start of a paragraph I can't remove.
Sorry, I probably did mean the TRC (Traction Control). Whatever, it's the button next to the fuel filler door and has a car skidding on it - presume its the TRC rather than ABS.
Yep, TRC switched off to allow the tyres to cut through the snow. TRC on = brakes trying to stop wheels spinning = no progress.
