Service
roger_37
hi all, going for my first 20,000 mile service
what should i expect mr t to do for first 20k service
any help would be appreciated.
roger
roger
On top of the usuals, he will also change your brake fluid. Tell him not to do pollen/cabin filter.... buy one yourself and fit in minutes.
Big Kev
Service guide says;
interval_box.gif Replace engine oil and filter
interval_box.gif Rotate tires
interval_box.gif Visually inspect brake linings/drums and brake pads/discs
Additional Maintenance Items for Special Operating Conditions:
Driving While Towing
interval_box.gif Tighten nuts and bolts on chassis and body
Driving on Dirt Roads or Dusty Roads
interval_box.gif Inspect ball joints and dust covers
interval_box.gif Inspect drive shaft boots
interval_box.gif Inspect engine air filter
interval_box.gif Inspect steering linkage and boots
interval_box.gif Re-torque drive shaft bolt (4WD)
No, more than that on a 20k service. It should be transmission oil (transfer and rear axle) as well as the oil change. They will charge you extra for brake fluid and filters unless you get a service plus which will bump it to £299.
Don't be afraid to barter.
thanks don, i didn,t know that,booked in for this thur.
would like to change brake fluid... but how to be sure they do all the work.
roger
Just ask them exactly what you are getting for your money. As Kev says you can buy a cabin filter and an air filter and pop them in yourself. Ask them about the brake fluid but they should really do the clutch fluid as it is fed off the same reservoir. Tell them what you want to pay for then barter. They will usually have a go at competing with a local garage so wait for the price and then go lower or throw the brake fluid in etc.
great advice don, will do as you say, air/cabin filters will do myself. was quoted 235 euro,
so will see how much extra they want.
roger
service complete,all oils replaced , along with cabin and pollen filters,
very happy with service all done for 235 euro
roger
