Climate Control
Marshy135
Is there anyone who could help me out I have a celica t-sport the climate control won't change the direction of where air is blowing everything else is working
Thanks dan
  • 3 months later...
Bit late as a reply but at a guess I would say the climate control panel needs changing (electrical fault) unless you can hear it trying to change position.. then mechanical.. Climate control panel is relatively easy to replace..
No problems I found the problem was a missing part I replaced a white plastic arm it works a treat now thanks for the reply though
