Fuel Filter - Bleed!
Nigebob Squarepants
Does anyone know how to bleed the Fuel Filter to remove build-up of water (cheap fuel),
before anyone comes on berating me for using supermarket fuel, I 95% of the time use Shell
diesel or V Power, so go figure!
I was advised that bleeding the filter was possible and to do this as a first measure if I ever had
any problems with the car hesitating, before going on to replace the filter.
Bye-the-way, I have already replaced said filter and the car is now performing as normal.
I didn’t know there was a bleed (nipple/screw) or whatever on it!
Or was the chap talking through his posterior :jester:
Any advice greatly appreciated.
Thanks! I didn’t see it in the pinned section… I wasn’t looking at the 4.3 as mine is a 4.2, but I presume it is the same? :ermm:
Same sort of procedure, different filter on the earlier 4.2's
Kingo :thumbsup:
If you suspect water has or is in the filter change it.. It really is a simple job and cost is minimal...
I realize you've changed it once but still worth changing if any indication of water ..
+1 For the cost it is not worth bleedin messing.................see what I did there eh eh?......I'll get ma coat
don’t forget you’re hat!
Excellent pics on the link… I could eat my dinner off that.
Your caring sharing TOC has a 4.2 filter thread;
http://www.toyotaown...=90#entry886270
To drain the fuel filter of water you slacken the plug in the white bit at the bottom but you would get a warning light as there is a float switch in there. I doubt you would ever benefit from pumping the plunger unless there was air in the system.
