Traction Control
Mike1977
I have an 06 celica gt and when cornering to the right the left hand front wheel starts to brake through the abs, I have had the the sensor replaced but am still getting the same problems any ideas?
Not sure if a sticking caliper would cause the ABS to kick in, as tha car also has Vehicle Stability Control so it puts the brakes on automatically for you.
You could try turning of the traction control, but not sure if it turns of the VSC at the same time, and see if it does it then, but be careful.
