Celica Gen7 Power Windows Master Switch
jdar
I wish to modify the master switch and replace the passenger side power window motor to get both power windows works as auto mode(Single touch).
I know that the power window motors are different from each other, but if I will change the passenger side motor and use a similar one as the driver side, it will be possible to modify the master switch and they will work as auto mode?
The circuit of the master switch, is capable to deliver both power windows at the same time?
Thanks a lot for your help.
