Toyota Iq 2009 Petrol
ulrick
Hi
Im after a detailed description possibly inclulding pictures how to change the Battery on a 2009 Toyota petrol.
All help appricated!
Many Thanks
Ulrick
Well the Battery changing method for all cars is same. I don't think you don't anything special for your car. First you need to put out the cigarette lighter and plug in the memory keeper. Then you have to just unplug the cables from Battery and clean them and install a new Battery and plug the wire with the same as it was on previous battery. i mean you need to check the positive and negative wires that don't mix them. here are the photos, hope they will help you.
Apply battery lithium grease - Spray the terminals with lithium grease to prevent corrosion.
