If you have defficulties with just starting the engine not when the engine runs so it can not be injectors.
  • 1 year later...
I'm having a similar problem but mine is two or three times a week I press the button to start it fire's then stops and turns over a few times until it has repressurised the system and starts fine I'm sure it's a lack of pressure but only occasionally is the bit I don't understand I changed the scv valve not made much difference just wanted to know if there is a non return valve in the fuel system
