Tapping Noise From Bottom Of Engine On My Estima Lucida 93
robbie1970
hi just wondered if anyone can help. i have a 93 estima lucida. just done oil and filter change and still got a knocking tapping noise from bottom of engine when it warm. the car drives brill other than that. thanks.
It may be that a thrust washer between engine and transmission had disintegrated (or was missing) which in turn allowed over half an inch of 'end float' of the crank shaft to damage a plate which joins the flywheel to the torque converter. (This plate seems rather flimsy considering the forces involved). That may account for the noise.
Big ends! - It does it when warm when the oil is thinner.
Does it seem more pronounced at a certain RPM? (about 2300 was the "sweet spot" on a supra from memory)
thanks is this expensive to repair.
it ok when engine first starts but as gets warmer it sounds more. is this serious or nothing to worry about. thanks.
thanks. is this expensive to repair.
£200:00 to £250:00 for the above, but it may be best let Mr T quote you first, I may be wrong
