Hello,
So i need to find the little bugger first.
My little Aygo is using just a little water, or should i say the expansion tank drops a very slight amount in the 2 months i have had it.
I have changed the oil with no sign's of water in there, there is also n sign of oil in the Rad, or any misfires so i dont think its the head gasket.
It does however have the old style water pump fitted, so im thinking it could either be the pump, Temp sensor or a weeping Rad.
Any ideas ?
If your Aygo is less than 5 years / 60,000 miles old there is a warranty extension in place for a leaking water pump.
Devon
